Hi,
Does anyone know how to control the location of Shake Macros in the tabs?
They seem to pop up anywhere in the list (usually at the end but not always).
I made these two nodes that I hoped would be next to each other in the gui but they are separated
by the other nodes in the User tab.
Example: Macro1.h and Macro2.h files were created. When I click the User tab, Macro1 is at the beginning of the list and Macro2 is near the end. It makes no sense how these are being ordered. It's neither date based nor alphabetical.
Any ideas?
they usually pop up is in alphabetical order (or as the app loads them which is usually in that order). the only way i can think of to get them where you want is by bundling multiple macros per file. I am not 100% sure of how this process goes, but i guess it would be a good thing for me to look into. one person i would try asking is the guy who made the pro flares macros. he bundled all of the UI buttons into a single .h and UI.h file
by doing this multi macro per file, you will be able to get them not only in the order you want, but there will be less for shake to load.
go download my Flixor macro pack... i formatted the script pretty clean. if you open the header and UI header files you will be able to see how the macros are laid out and you will see it is much easier than it sounds lol
