Mad as an Attr
hi,
I have a locator with added attributes for
controlling a skeleton. In my zeal, I neglected
to add a min/max to one of the attributes and
just can't seem to figure out how to edit it so
that I can include a min/max parameter range.
Further, I could do with reordering the attributes
so that they list more clearly in the Channel Box.
Again, can't figure that one out either!
I was going mad setting up the Set Driven Keys for
the other arm and hand of the skeleton. If anyone
has any tips for speeding up that process I would
love to hear from you.
Cheers,
Ivor
Hi,
I doubt that you could reset the min or max or reorder the attributes in the channel box inside Maya. I remember someone pointed out that you could actually save your scene into Maya Ascii file. Then, you text edit the file by changing or adding the min or max or by reordering the lines of the attribute. Try it, it works.
rgds,
pipit
There is a script by a|w that basically deletes the attribute, but "remembers the connections" and allows you to reset the min/max attrs etc. I made one too that allows you to rename attributes. All it basically does is store the input/output connections and then relink them. I think the a|w one is called editAttr or something like that. Dunno where you can find it though.
-comet
save out the scene as a .ma.... open it in your favorite text editor. find the part that creates your locator. find the part of that adds the attributes. reorder them here. as far as i know this is the only way to reorder them.
you can rename attributes in maya 3 via the interface. or you can use the afore mentioned method, but be careful.. you will need to re-attatch the attributes by hand if you use the afore mentioned method... there is a script out there that allows you to change the min max values of an attribute and it does all the reattachment automatically. its called editAttr.mel or something.. you should be able to find it pretty easily, its probly on highEnd.
hope this helps some...
hi,
Thank you all so much for helping me
solve that one. I'm not so mad now!
I did the ascii thing, by the way,
but I'm just off to find that editAttr.mel
Cheers,
Ivor
