Major Mental ray options and errors
first I need some help...
I am running a dual xeon 2.4 with 2 gigs of ram and a page size of 4 gig max with hyperthreading...
the first question is... Mental ray manual says the default physical memory allocated is 512, this is done by setting it to -1 should I manually set it to something else
also the virtual memory is set to 0 wich means unlimited
what are the best settings??
I have tried batch rendering my scene 3 times, the first it rendered all the frames... the 2 and third it stopped halfway and said it ran out of memor or something like dat
also should I manually set a bsp max memory??
I am using a setting of 5 and 70 for the bsp
but the max bsp memory tab is set to 0 unlimited should I limit it?? I read in the manual that this might be the cause of the premature rendering since I am doing multiple threads
Bump
Bump@2
