Make A Avi In Shake 2.5
hi folks..
i am new to shake...
i want to export AVi files.....
i have dont file out node.... how can i create avi files...render....
help me
another doubt... is
while comosite.... the fg image and bg image merging... like photoshop feathered image.... this proplem only comming importing two images...
help me....
Shake only supports movie files that quicktime supports, not any directshow codecs. So pretty much cinepak, bmp and dv.
QUOTE(beaker @ 03/12/06, 09:49 AM) [snapback]230779[/snapback]
did it already support qt in 2.5?
otherwise i imagine the only way is to use another program to convert the image sequence to avi..
gives more options anyway.
++ christoph ++
Yes, qt support was added to 2.2 or 2.3(I forget, its been a while). So this was a pre-Apple aquisition decision(everyone assumes that Apple did this). I'm purely guessing here, but I assume it has to do with the constant interaction compositors have with files outputted from an Avid edit for matching which back then was 99% quicktime since windows based avid solutions were brand new at the time and still very buggy.
Just use quicktime, it works just fine. There is a mpeg plugin here on highend, but it isn't a great solution unless you just want a delivery format for the client that everyone is guaranteed to be able to read.
