Even if XSI adds this option, I wouldn't suggest that you use it. Direct rendering to video is a bad idea. If your computer crashes/power goes out/little brother kicks the plug out of the wall/whatever, you might lose the entire animation. If that happens when rendering frames, you only lose the current frame.
If you just want to do a quick test avi, use the capture function. It renders directly to Avi.
