Hello guys ! I'm making a cube rolling with the Mel command "MakeRoll"
I used the line "makeRoll pCube1 0.0 true 1.0;"
and my cube works nice... but I can't animate it !! I mean... also if I keyframe just the Translate X or Z when I play my animation the cube float and doesn't rotate anymore.
Do you have any soggestion ??How can I animate it (keyframe it) ?? thank you !!
Not sure I understand your question... i just copy and pasted your code into maya and it keyframes and animates appropriately. Is it not letting you keyframe? Or is it translating on the x and z and just not rotating? If its the latter I would suggest deleting the expression on the transY and trying the code again.
