Ah, yes I know I can pull as many strings out of a node output as I can imagine. But what I want is a node with 3 output blobs so I can pull 3 different outputs from the same node without having to add reorder nodes.
Something like this channel split node (witch I created in photoshop):
I hope that explains it better.
Then there will be 3 separate outputs from the same node, and I can easily do what ever I want to the individual channels.
I know this isn't the most complicated thing to do with a few reorder nodes, but I want to put a little more to it than just splitting R G and B, and I have to make this kind of setup quite a few times on an upcoming job so I would really like to get this little setup with as few button pushes as possible.
I haven't seen a single node with more than one output, so I guess it is impossible to make it directly as a macro.
But a group node can have more than one output blob, so I was thinking if it is possible to make a macro that imports a little .shk file that contains a group node with more than one output and expressions on the nodes inside the group node??
kind regards
-johs
