Hi all,
I have a .jpg of a stained glass window. I threw it on a generic blinn, but I want it to allow light through using raytracing. But the problem is that I can't adjust the transparency in the attribute editor. Any ideas?
Ryan
Hi all,
Ryan
one way to do it that would give you a lot of control would be to plug in the jpg image into both the color and the transparency of your shader. now adjust the color gain and color offset in color balance for the image plug'ed into your transparency. the darker it is, the less transparent it will be. also if you are getting too dark of shadows another thing to adjust would be the shadow attenuation under your raytrace options for your surface.
