I’d love to ditch Windows and I might have a chance at uni to experiment - can anyone give me a fairly-newbie list of essentials for sorting Maya out on Linux Mandrake, or is this one of those “use redhat” moments? From reading the board it sounds like A|W don’t provide everything you need with the program, so if they ever make PLE for linux this info would be equally handy…
A standard Mandrake 9.0 and the newest 9.1 will take an install of Maya 4.5 perfectly fine. Just make sure you have X windows setup to be in 24 bits. Otherwise Maya will exit with an unknown error. I believe a Signal 2. Also, it’s important you have your video drivers installed and configured properly. If not you may run into some more crashes. Other than that, you should be good to go. Hope that helps a bit.
