Am quit new Linux world which is growing badly big and Hmm confusing, Got this question at the moment:
What version of what Linux would fit best with 3D app including Maya, Nuke, Mayaman, prman And Massive ( Of course when I robbed a bank ),
Cheers
Cheers
i got very good experiences with Debian Sarge (3.1), bad experiences with Fedora Core 2 or Redhat 9.
i advise you to use Debian, but this distro is hard to handle . . . when you are new on linux than use SuSE. But i think Suse is less stable less efficient by using your Hardware.
There are surely other good distros (i.e. gentoo), but i have only worked with SuSE, RH and debian
Why do you think Novell’s distributions (ie: NLD, SuSE Linux Pro) are less stable and less efficient? I’ve found SuSE Linux Pro to be very stable and efficient not only at handling memory but with the GUI tools such as YaST that offer power as well simplicity to the end user. Also, Novell’s distributions are the only ones I found that offers a package that fetches and auto-installs NVIDIA 3D drivers.
Anyway, Novell’s distribution SuSE Linux is now certified for use with Softimage XSI and Alias Maya. For those not aware Novell’s distributions are RPM based and use similar Terminal (aka: BASH, Shell) commands as Red Hat’s distributions (also certified for use with highend software such as XSI and Maya). Where as Debian based distributions (ie: Linspire, Debian, etc) are not certified for use with software such as I mentioned and use commands not typically used on RPM based distributions. Meaning it’s not useful for you using a Debian based distribution at home then trying to apply those same skills in a studio using for example Red Hat Enterprise Linux. Also, another thing to take into consideration is that developers such as Novell, Red Hat and Mandrakesoft all have received LSB (Linux Standard Base) certification for their software where as Debian distributions have not (at least none that I’m aware of).
As for stating that you’ve used highend software on a Debian distribution successfully would seem to make light of the issue. To do so most users need to convert the software files to properly install on a distribution it wasn’t intended to be installed on in the first place. Tools such as Alien will attempt to convert the software from .rpm to .deb so as to try and install on a Debian based distribution. Since as I already pointed out Debian distributions lack LSB certification there is greater chance the software will either not install or not install properly in the right directories. Doesn’t mean it isn’t possible to install software compiled for RPM distributions on Debian distributions, just that it’s more difficult and time consuming than some make it out to be. When paying several thousand dollars for software I’d rather install it on a distribution that is either 1. Certified for use with the software or 2. Follows set standards, thus has a set file and command structure similar to the certified distribution.
hi,
Right now all distro support for multimedia… and ofcourse you should use the good hardware support like nvidia graphics card that very-very support linux user. but for profesional use, like multimedia home desktop and workstation, there are 3 distro that i think the best. there are Mandrake, Redhat and Suse.
Mandrake, and Suse is the best for Multimedia…workstation and desktop. and i ever use suse and mandrake to run maya. but in suse 9.1 its look bugs in GCC, hope its fix in suse 9.2. right now i use mandrake 10.1 PowerPack and KDE 3.4rc1 and running smoothly. My Maya 6.5 for Linux running in my mandrake.
For other distro i think the best coices, like Debian and Slackware.. there are free and opensource. and other people report that nvidia driver card can running in those distro.
Suse and Mandrake have the powerfull Tool (Mandrake Control Center and Suse Yast2). and the conclusion is whatever distro that are you choose its no problem.. and all the support you can find out in internet. but the easy use distro is Mandrake and Suse.
Thank You and sorry my bad english.
Teddy Widhi L.
Penguin Power
first of all: I like SuSE, that was my first Linux Distribution ! It easy to install and handle, it offers the newest Linux benefits and as you say it its LSB certificated.
I am glad that there is a Linux like SuSE if someone wants to start with Linux !
But the disadvantages are:
Thats why i love the handling of debian ! and its not problem to get the same multimedia functionality like SuSE, RH or Mandrake. You just have to install some packages . . .
That I have to convert the Package is no problem, alien works very well . . . strictly speaking is it not to convert the package, it just adjust the postrm, prerm, postinst and preinst Scripts that the package brings along.
You are right that it is maybe more difficult and time consuming to install highend software on it(not with maya, but with other progs). But i am not sure if you have a greater chance to install it !! If you got problems with a package on SuSE its less likely that you can solve the problems or found a howto that explains a way !
what i mean with “less efficient” is that SuSE has like windows a lot of bots and automated processes (hotplug, automount, network checker . . .) that consume CPU and RAM for nothing and I’ve known it to happen that a system got serious problems because one of that bots produces bugs (i used Suse four years) !!
and in my opinion it seems less stable than my debian.
On both distros I was using the same window manager (openbox) and the same handmade kernel (2.6.8). And on Suse here and than there crashes a window (often GL stuff), on debian not.
Thats what I experience.
When paying several thousand dollars for software and hardware i want to have a stable workstation and a OS that makes the best out of my hardware ! If I want no problems and pay more money I buy faster hardware and a windows OS. If I have just enough money for software and adequate hardware, i don’t want to waste my ressources !
Than i need a distro like debian/BSD/gentoo, with a handmade kernel and only the packages that are needed installed. That is not easy to do, but when working on (expensive) highend software level than its better to work on well configured and light weighted Linux.
Why is pixar using BSD and not SuSE, Mandrake or Redhat ? And BSD is also not LSB certificated ?
I dont want to proselytise anyone to use debian, but maybe encourge someone to try and make his own decision ![]()
greetings
knecht
I’ll admit that SUSE is an attractive option for people coming from Windows. It also sounds like support for Debian is strong, and that it’ll continue. The older I get, the more I realize that time is money, and I’ve spent a lot of time configuring and installing software.
Either you’re the type of person that appreciates the careful work put into designing for usability, or you feel you’re above such concerns and tend to denigrate a good interface. I think that the work of Jeff Raskin, Alan Cooper, and others proved that everybody can benefit from software that is easy to use, even highly advanced users.
I can say that my experience with SUSE is that it is amazingly stable. I’d rank stability and ease of use above peak performance. For instance, most of us probably don’t overclock because we all understand that crashing in the middle of an all-night render doesn’t really do much good. I do know that SUSE Linux’s stability under high loads is undeniably better than XP Pro in my experience.
Just last night I rendered three scenes at once, exported an MPEG, and played another MPEG in Xine while also playing an MP3 in another Xine instance with no skips on a single Athlon XP 3000+ with 2GB RAM. This wouldn’t be possible when XP Pro was installed previously on this machine.
Good luck with Debian, I think the anarchy of distributions is heathly for Linux, allowing it to dodge corporate bullets, so keep it up.
quote:
------------- s n i p -------------
"Am quite new Linux world which is growing badly big and Hmm confusing, Got this question at the moment:
What version of what Linux would fit best with 3D app including Maya, Nuke, Mayaman, prman And Massive ( Of course when I robbed a bank ),"
okay, i’m going to chime in here just to back up knecht here. our suse friends are very enthusiastic about their fave distro, not unlike us debianites or fellow gentoo or redhat dweebs. So just to balance things out a bit …
Knecht is correct.
Our Suse friends are correct too ( it’s just that knecht is more correct >_> )
Look your starting out, it’s all going to be confusing. The biggest problem you are going to run into is that as a ( I presume ) Windows user you have 14 years or so of training under your belt. Please don’t forget that.
I deal with newbs every day that come to linux and go ‘but this was so easy on windows … waaah’, they forget just how ingrained they are in the Windows world (14 years of slavery changes the mental process). Things seem harder at first but after about a year of tooling around most people go ‘holy [censored], this is far easier than on windows’ … and for most things it is, I won’t go into details, but by the time you are experienced in the desktop environments will have yet again moved forward in featuresets making things even easier.
The second problem you will run into is the ‘google it factor’. We are working on it slowly, but because the Linux world puts the power in the hands of the user, most people figure out very quickly that it’s more fun to ‘create / code’ than it is to document. In a roundabout way you are expected to be ‘born with the knowledge’ as some have commented, but what that in practice refers to the idea that the online world is a global mental core dump, a sort of conglomorate backup memory storage device of all our knowledge (not exactly true but more so every day). There is an underlying expectation that you access this core dump of human knowledge ( it’s skewed very much in favour of computer related fields, and as such, Linux in a way is evolving as a result and in conjunction with this real time core dump of knowledge … a co-symbiosis of sorts) first before asking questions in forums, irc, etc.. In other words, you already do have the knowledge, you just need to ‘remember it’ via google. Neat huh?
Okay, admittedly the information could me more organized and thorough, but that will come in time. I’m hoping to spin a perspective on some of your upcomming experiences. Nothing wrong with asking, just when you get an ‘rtfm’ type of response, think of the paragraph earlier, it’s what they are obtusely referring to.
Thirdly, in the end Linux is Linux. All your needs can be met with almost any Linux distribution. You know what? You can build your own Linux distro from scratch to match the specs of your software by following these sites:
www.linuxfromscratch.org ← linux from scratch
http://lfs.crash404.com/blfs/news.html ← beyond linux from scratch
Pretty damn cool eh?
Okay, do this as a newb: download every goddamned distro you can. Go ahead and run Suse, Gentoo, Mandrake, Redhat, or anything else.
Then at the end try Debian. You will see very quickly why Debian is a remarkable distro. As of right now, Debian ( Sarge version about to be released, last debian official release had something like 9, 000 packages) has 15, 000 precompiled packages, that are all tested, all updated and all dependencies resolved for you. To install a package you just do ‘apt-get install ’. There is a gui called Synaptic to let you select and install packages and their dependencies If you want. To install .deb files you download from various online resources you can just do ‘dpkg -i packagename.deb’ … etc. Super easy.
Debian is also ported to something like 11 or so architectures. so thats 15, 000 pieces of precompiled, tested, secured and dependency resolved on:
aplha
arm
hppa
i386
ia64
m68k
mips
mipsel
powerpc
s390
sparc
What most people fail to realize how huge of a project Debian really is. It is bar none, THE BIGGEST, baddest mofo distro out there, and all the dependency hell you will run into on the rpm based distros doesn’t exist, AT ALL. Sure glitches exist, hell its one of the biggest software projects on the planet, but it’s pretty darned good. What you should start to realize is that almost all of the software in all of the other distros is already precompiled, pretested, dependency resolved and present Debian. There is of course software particular to Redhat or Suse but the percentage points of that is something like in a handfull of % at most.
This however, is simultaneously ( appologies to any Matrix fans for the reference ) Debians greatest strength and greatest weakness … while simultaneosly the largest and arguably one of the simplest distros to use, the last Debian official release was something like 3 years ago. It’s is one bitch of a project to get volunteers to package, test, debug 15 000 pieces of software simultaneously on 11 platforms while reingeneering a whole bunch of things. Let me put it to you into perspective - that would be like Microsoft actually porting all of their products combined, three times over, to 11 different platforms not one, and releasing all of them simultaneously on a regular basis … staggers the goddamned imagination frankly. Of course Debian developers are only packaging and debugging and porting, not actually coding the software from scratch but it is still a project of incredible proportions. Some discussion is going on about moving to Debian to a time based release process like Gnome, some like the idea some don’t, but it doesn’t matter for you at this point.
Try all of them young padawan, try Debian, if you like it great, if not whatever. Choose what works for you, all of them are fine choices.
You know where my vote stands.
Thank you very much MR . . .Hmm m m Bean ???
I really appreciate the detailed data you have posted.
The only thing is I am not a one that who is supposed to WORK on Linux, I mean not as IT person or someone who has a daily interaction with Linux, I need an stable, fast and supporting version that helps me concentrate on my work( 3d, Effects ) without having the hassel of OS problems, Currently using RH WS 3 am facing problems with crashing and . . .
The other Nutilus crashed and didn’t let me get into either gnome or KDE the only accessible thing was failsafe mode, I had to Reinstall RH, I am sure there is a way to simply sort it but it is just not MY WORK , I don’t want to waits half of my study time to sort the operating system.
At the moment am downloading Debian, Will write back in Sunday when I had it tested.
Cheers Guys
Thanks again
just a heads up …
… you should be downloading this:
http://www.debian.org/devel/debian-installer/
1 cd netinstaller, and really only installing what you need (if you are on a high speed connection). RC3 there is new i haven’t tried it, rc2 works great.
A bit of extra info …
Debian comes in 3 ‘flavours’:
a) a current ‘stable’ release, which right now happens to be Woody.
an upcoming ‘testing’ release, which currently is Sarge
c) an unstable release, the current unstable release is called Sid
The link above is the netinstaller for testing “Sarge” release, give that a try first.
If Debian doesn’t end up being what your looking for, don’t forget it’s fine, we’re all passionate but you obviously have specific needs.
Hi
Thanks for the quick reply,
Can you be a bit more specific ,cause am downoading debian DVD through Hmm what is it jidgo ot jigo what ever command line downloader , it is tellin me the whole DVD size is around 4 gb which I think will be finished be evening , How ever am trying your link as well ( netinst ( i386 ) ) which is around 107.6 ISO file is that all ???
Can find me on a_jahanlou at yahoo messenger if you ever use .
Thanks again
@Mr.Bean
nothing to add
i am glad to find so open minded people here . . . think there will be a brave GNU world soon ![]()
@amir jahanlou
that is an netinstaller, that means you just download about 100MB, and install a basic system with it on your PC. Then you need internet access (DSL over router is the easiest way) and the Installation continues with asking you what to install. Then the needed packages will be downloaded and installed
here some links:
http://www.debian.org/releases/stable/installmanual
http://www.debianhowto.de
http://www.debian.org/doc/ddp/
http://wiki.debian.net/
very good forum:
http://www.debianhelp.org/
there are forums like these in any language available, just search !
if you need a package which is not in the official amount of packages
http://www.apt-get.org/
and because I am german,
http://www.debianforum.de
http://forum.neoberserker.de
Hi
Am back again
Well when I first post this tread I meant something rather stable and simple for an artist, Not a technical person .
Currently it’s a couple of days I am struggling to INSTALL Debian
Am not sure when I had it how I am gonna install my Packages.
I have 10 CD’s
Debian 1 - y
Debian Update 1 - 2
Debian Nounos ( meaning less to me )
And still cant get any graphical interface.
Am wondering does it have any graphical interface.
Besides If I have RPMs is there a way to install them, or I need to find new softwares and compilers and . . to make it.
Come on guys give me some help before I get back to Redhat.
Am badly disappointed that I can’t install an OS.
Thx
Be shure there are any GUIs (Gnome 2.8 or KDE 3.3)
what distribution do you have ? ("3.0 woody stable"or “3.1 sarge testing” ?) I recommend 3.1 for working with maya !
there are install instructions everywhere, also how to handle the configuration of the xserver . . . but you have to read them ![]()
Its not easy to install, but when it runs nothing can stop it.
you need at least the packages:
xfree86-common
xserver-xfree86
(install with (as root)
apt-get install xfree86-common xserver-xfree86)
and you have to configure your XServer with
dpkg-reconfigure xserver-xfree86
then a window manager (kde or gnome)
if you search a package you have to type
apt-cache search what_you_search_for
there are manpages for almost everything
man apt-get
man smb.conf
read them, and take a look at the links, then everything is easy
amir …
put away those 10 cds, and just download this as per previous post:
http://www.debian.org/devel/debian-installer/http://www.debian.org/devel/debian-installer/
its a live installer, 1 cd, you can download the rest of Debian over the internet. it will autodetect everything for you and ask if you want a desktop, server, etc. type of configuration. obviously select desktop, and it will download and install kde and gnome over the net.
once you have downloaded the live installer and started the installation process, if you get stuck, post a question, we would be happy to help.
Finally Got Debian On my Machin
There 2 Issues
X Server can not be loaded
Error comes as
" can’t find any screens "
While I have configures XF86Config exactly the way I used to do in RH .
Secondly how Can I install rpm Packages, How should I convert them to .deb.
Third When I try to install Graphics card driver ( obtainedfrom Nvidia Offical website ) It says there is no Kernel installed, Would you like to compile a kernel from ftp://nvidia . . .. .
Am posting all these in forum as well.
Cheers
do you know which version of xfree your RH use ? because debian sarge uses XFree 4.x, and if RH has a similar one you can simply copy your XF86Config from RH to Debian.
You can also do so with knoppix live cd ! when you copy a XF86Config to your debian you mabe have to install additional xserver packages (because if knoppix or RH uses extendet features, you need them on your debian box, too)
