Manipulators and vertices
I have created a freepointtriad manipulator (the standard move manip) and i need to be able to attach it to a vertice, so the vertice moves with the manipulator. I've been try to work this out for a long time, so if anyone can help it would be greatly appreciated.
-Thomas
couldnt you use clusters instead?
I've tried clusters but it didn't work as needed. Anyone??
Did you read my reply to your other post regarding this subject? http://www.highend3d.com/boards/showthreaded.php?Cat=&Board=mayadevelopers&Number=77390&page=&view=&sb=http://www.highend3d.com/boards/showthread...page=&view=&sb=
I tried the controlPoints plug. Use MPlug::elementByLogicalIndex() to get the correct point in the array. As I said in my previous message.... I had problems (crashes) when the mesh had input/output mesh connections. Also try the pnts plug. I never had real success and eventually abandoned manipulators but I'm hoping you'll fare better than I did. Let me know how things work out.
-jd
