Mapping secondary Attributes per Voxel
I want to create an effect of growing mold on a rectangular region. What I allready have is:
  • a 2D fluid with only temp and fuel
  • fuel is based on inported image
  • in one edge some heat to start the reaction
But when i play back the animation the reaction is to uniformly.
How can I modify the per Voxel attributes for Reaction Speed? There is a map-button, but nothings happens if I connect it to a fractal for example.
It is also not possible to block the heat with an nurbs object and collision turned on. :c(
Any suggestions?
You can use larger amounts of fuel in the regions you wish to mask out.. the larger amount of fuel will take a very long time to burn, effectively appearing like it can’t burn. In a sense one should not be able to have more than a density of 1.0 for fuel in a given region( the region is 100% unreacted fuel). However the simulation allows any density, so you can super saturate some regions. By making the fuel density vary, you can also affect the uniformity of the reaction. You may also need to adjust the temperature diffusion, dissipation and reaction speeds to get the best effect.
Duncan
