Matrix Element Must Be A Scalar Numeric Type.?
Error: Line 127.20: Matrix element must be a scalar numeric type.
tweaking i get this error in teh same line:
Cannot convert data of type float[] to type float
the errors are in this proc
proc vector getPosition (string $obj)
$x = getAttr ($obj+".translateX");
//string $type = getAttr -type ($obj+".translateX");
//int $size = getAttr -size ($obj+".translateX");
//print ($type+"-"+$size);
[b]vector $vvv = <<$x, 0, 0>>;[/b]
return $vvv;
i dont understand anything, specially cause when i try the code in the procedure appart, i dont get the error!
thanks!
//GLOBAL VARS
global string $cellarray[];
clear $cellarray;
//PROGRAM
string $selectedcells[] = selectedNodes;
initialize_array($selectedcells);
initialize_attr();
initialize_position();
int $iterations=0;
while($iterations<2)
    positioncells();
    $iterations++;
    print ($iterations);
//INIT PROCEDURES
proc initialize_array(string $selectedcells[])
    int $i;
    for ($i=0; $i<=(size($selectedcells));$i++)
        $cellarray[$i] = $selectedcells[$i];
    print ($cellarray);
proc initialize_attr()    //add atributes
proc initialize_position()    //store original location
//REACTION PROCEDURES
proc positioncells()
    vector $vAvoid;
    for ($cell in $cellarray)
        $vAvoid = avoid($cell);
        print ($vAvoid);
        refreshcells($cell);    //, $vAvoid
proc vector avoid(string $cell)
    vector $v, $cposition, $tposition, $result;
    float $dif;
    for($target in $cellarray)
        if ($target != $cell)
            $cposition = getPosition ($cell);                                            //store them in vector
            $tposition = getPosition ($target);
            $result = subsVectors($tposition, $cposition);
            $dif = mag($result);
            if ($dif > 3)
                $v = <>;
    return $v;
    print (" r:"+$result+" v:"+$v+"[]");
proc refreshcells(string $cell) //, vector $v1
    print ("refreshing "+$cell+"||");
    //print ($v1);
//VECTOR PROCEDURES
    vector $vvv = <>;
    return $vvv;
actually i found the problem
the $cellarray was 1 item bigger than the actual number of objects, so one was empty
giving the array the proper size fixed the prob
;-D
