Hello all, I downloaded the max 2 xsi plugin from ed harriss’ page and installed it into v3.1 but when i try to use it all that is imported into xsi is a new camera with out the model that i am trying to bring across?
any ideas?
thanks
al.
I had the same problem..hope someone knows how this works..The only thing it works is to export iges files from xsi
but of course this is only for nurb models..anyway maybe xsi2.0 has a built in import and export for 3dsmax or even better dwg files!!!..:-))
freeze all objects then export to xsi .(convert to editable mesh)
might work .
I heard there will be a max import/export in V2… nut I’m not sure
Yes, at SIGGRAPH they showed a plugin for Max and Maya that would export XSI files and said that it would be part of 2.0.
I believe that the MAX2XSI plugin on my site writes an older XSI format that is not compatible with the current versions of XSI. But, having not used it in a long time, I can not be sure.
I usually export OBJ from MAX. I’ve found that it produces really clean, error free models 99% of the time.
Ed
XSI Videos, Classes, Tutorials, Tools, Shaders…
Available at:http://www.EdHarriss.comhttp://www.EdHarriss.com
