Hello all, we have installed Maya2008 on CentOS5. We are having a rendering
problem. We have read through a lot of forum posts/answers, but can not seem
to find the solution to this problem.
## Centos Version ##
-bash-3.1$ cat /etc/redhat-release
CentOS release 5 (Final)
-bash-3.1$ uname -a
Linux cd4 2.6.18-53.el5 #1 SMP Mon Nov 12 02:14:55 EST 2007 x86_64 x86_64 x86_64 GNU/Linux
-bash-3.1$
## End Centos Version ##
Basically, it will render a few frames and them terminate with signal 11 unknown failure.
Strace proved useless, so I set MAYA_ENABLE_CRASH_REPORTING and received the following below.
Note that this was working fine on FC8, but the company is moving to CentOS for other reasons.
(I say this to mention that it did work at one time and the license mgr, etc seems to work fine).
Any help/suggestions/insight would be greatly appreciated.
Thank you.
maya encountered a fatal error
Signal: 11 (Unknown Signal)
Stack trace:
/lib64/libpthread.so.0 [0x3fd1c0de60]
erfc
TdnAnisotropy::compute_shadow(float, float, float, float, float, float, float, float, float, float)
TdnAnisotropy::compute_BRDF(float, float, float, float, float, float, float, float, float)
TdnAnisotropy::vectorComputePlug(Tplug const&, TdataBlock&, unsigned int, unsigned int)
TDNdispatchCompute::dispatchCompute(TdependNode*, Tplug&, TdataBlock&, unsigned int, unsigned int)
TshadingOpus::shade(unsigned int, Tsample**)
TsampleManager::dispatchSamples(unsigned int, Tsample**)
TtriangleWrapper::fillShadingSampleVector(int, Tsample**, TshadedRecord**, TsampleManager*)
TmaskedTriangleWrapper::fillShadingSampleVector(int, Tsample**, TshadedRecord**, TsampleManager*)
TgeomSampleRecord::fillShadingSampleVector(TshadedUnit*, TsampleManager*) const
TtileRenderData::doSampling(TsampleManager*, TshadedUnit*)
TtileRenderData::EASSampleVector(int, int, int, int, int, int, int, int, int, TshadedRecordList*, int, int, bool, bool, int const*, float*, float*, TsampleManager*)
TtileNode::sampleNextScanline(TsampleManager*)
TtileNode::renderTileScanlines(int*)
TrenderFrame::mpRenderTiles()
/usr/autodesk/maya2008-x64/lib/libRenderSlice.so [0x2aaab1e05625]
TmtThreadSubPool::sThreadStagingProc(TmtThread::TmtThreadInfo*)
TmtThread::fork(void*)
/lib64/libpthread.so.0 [0x3fd1c062e7]
clone
Result: /data/BuildingAnimations/renderScenes/Render.ma
Fatal Error. Attempting to save in /usr/tmp/number9.20080702.0900.ma
Segmentation fault
// Maya exited with status 139
