Hello everybody, I am since a while a maya 2008 user and everything works fine. Till now, all of a sudden maya gives a strange view in my user interface. The grid is running through the object and the perspective view isn't showing the grid and the object. (see my screenshot) Only if i zoom in closely to the object it shows the object and the grid.
I didn't change any preferences in maya 2008. I did update the latest grpahic card drivers.
My system specs: (system 1 en 2 running windows XP pro 32 bit) 1) AMD athlon XP 2600+ - 2 gig ram - GF 6800LE 2) Pentium 4 2.7 gig - 1 gig ram - GF 5600FX (always running maya 2008 fine till now) 3) Intel dual core 2,3 gig - vista premium 32 bit - 3 gig ram - ATI card on board (laptop)
After a clean instal all seems to be good working, after closing maya and re-open it the error shows again.
QUOTE(Mayarulezz @ 01/28/09, 04:48 PM) [snapback]299811[/snapback] I didn't change any preferences in maya 2008. I did update the latest grpahic card drivers.
Isntall a older driver back. Newer direvers dont equate to better ones except for games this traslates to glitches in everything else. So not all is equal here.
Even with a card thats actually supported you need to use drivers that are way older than the newest ones for maya to work correctly.
For exmple idf i sue the latet performance drivers with a quadro 3700, it will crash the gfx card under certain conditiosn whereas if i use the latest cuda driver version i have NO problems. And the driver is MONTHS older. The one they recommend is years older
Technology dont become better over time, it tends to get more optimal. But not necceserily to some specific use.
I installed several older versions of drivers for the geforce cards, but no difference. Strange thing is that it worked fine for months and now it gives suddenly problems, but i changed nothing!
Anybody (or you) more suggestions to try to solve this problem?
At the persp. camera attr. editor set the near and far clip to 10 and 9000. The settings at my pc was wrong numbers, so thats the objects in persp. were only seen at close up, not at far.
