Hi,
I have installed SQLAlchemy and it works pretty good with Maya2009 32-bit, but in Maya2009 64-bit I can't load mysql module. I got:
import _mysql # Error: DLL load failed with error code 193 # Traceback (most recent call last): # File "", line 1, in # ImportError: DLL load failed with error code 193 #
Any ideas? Oleg
Hi, is anybody used MySQL with maya2009?
Maya2009 64-bit
From Maya Scrip editor: sys.version # Result: 2.5.1 (r251:54863, Jun 7 2007, 16:23:10) [MSC v.1400 64 bit (AMD64)] # import _mysql # Error: DLL load failed with error code 193 # Traceback (most recent call last): # File "", line 1, in # ImportError: DLL load failed with error code 193 #
Maya2009 32-bit
From Maya Scrip editor: sys.version # Result: 2.5.1 (r251:54863, Jun 5 2007, 22:56:07) [MSC v.1400 32 bit (Intel)] # import _mysql _mysql.__version__ # Result: 1.2.2 #
Looks like maya 64bit used [MSC v.1400 64 bit (AMD64)] Python.
joojaa
November 25, 2008, 3:50pm
4
you are using a 64 bit mysql then?
I didn't found any python SQL plugin that works in 64 bit. We had to write a C++ plugin to get this to work. This is a pain. If you figure out how to make this work I would like to know how to do it in pure python.
You can compile 64 bit MySQLdb from source code. After compiling this worked great.
