Maya 4.5 bevel plus problem
Hi,
How do I make letters with holes eg.A B, D etc bevel properly in Maya 4.5 Bevel plus. If the alphabet & the hole is grouped then it does not bevel the hole properly. Similarly I cannot make the curves one piece using attach curve.
Thanks in advance,
Redman
You have to select the outer edge and then the holes. You cannot just select a group
Thanks Gmask, but even if I select the outer curve first & then the inner curve yet it does not Bevel the inner curve the way it should be. The inner Bevel looks more like an extrusion.
Redman
