I Recently loaded Maya 5 in my Dell M60 (mobile workstation ) laptop and discoverd that all my option menus are blank. Alias did mention that some dell computers may have this problem and offered a quick fix but no effect. Is anyone out there having the same problem or does Maya work fine on your M60"s need to know . Thanks in advance for your assistance.
Just figured this one out yesterday…go into your display properties and click on Advanced. Click on the tab labeled General and change the DPI settings from what ever to Normal. Then just click OK and apply and reboot if needed.
This worked for us once we rbooted after changing that.
Hope this helps,
I think I have a similar issue. My M60 has FX Go1000. The primary item under most attribute editor objects is empty. For example, the light has no light attributes (first submenu for a light). Is this similar to your issue? Does changing the DPI to Normal fix it? Are you Go700 or Go1000? Thanks!
