hi all,
we are using rh 9.0 and upgraded to maya 6.5, so far so good other than the space bar, in maya 5 you can automatically change panel through mouse over the panel and spacebar, but in 6.5 you need to click first in the panel and space bar, this is one step behind the work flow, is there any configuration that i need to do?
thanks a lot.
No issue here with the space bar on Maya Ultd 6.5 running on Novell SuSE Linux. A few things to consider. First try seeing if there are any adjustable window settings in your GUI control panel and if so play around with them to see if you can get better interaction with Maya’s GUI. Since you mentioned your team is using RH 9.0 I’m assuming your desktop is Gnome based. Second try updating your desktop (ie: Gnome, KDE, etc) to the latest version or better yet consider switching to a supported distribution or at least more current. After all not only have there been a lot of improvements made to desktops such as KDE and Gnome but also having a supported distribution provides less headaches. Some alternatives for a studio are Red Hat Enterprise Linux WS, Novell Linux Desktop, Whitebox Linux, Mandrake Linux Corporate Desktop, etc. Even Fedora Linux may be an option for your studio. Just as with RH 9.0 it lacks support from Red Hat but at least offers more current packages found in commercial distributions.
http://www.novell.com/http://www.novell.com/
http://www.mandrakesoft.com/http://www.mandrakesoft.com/
http://whiteboxlinux.org/http://whiteboxlinux.org/
http://fedora.redhat.com/http://fedora.redhat.com/
This is a window manager issue, not a maya one. It depends on how your window focusing is set. You need to set the focus to follow your mouse, right now your WM has it set to you having to click on the window to set focus.
Hi,
Its no problem in my KDE 3.4 and Fluxbox 0.9.12 that run on Mandrake 10.1 PowerPack. Maybe its the WM issued.
Thank You.
Teddy Widhi L.
Penguin Power
