Hy guys, i’ve a little problem with maya and linux, everithing works fine, !!! But when i press the spacebar to switc from one view to the other, sometimes it quits maya, the only message that i see is : the console stopped with a signal (and a number).
Now i’ve turned off execute in a terminal, and till today it hasn’t crasched again, but i’ve used it just a half an hour, i’m sure that the problem is unsolved…
Any hint or suggestion ?
Thanks in advance
Brogh
Alea Jacta Est
What version of the nvidia drivers are you using?
I’ve updated the driver yesterday with version 1.0-6111, at the moment it seems OK, but i have to use maya intensively before being sure that the update fixed something, … but yesterday maya didn’t crash… we’ll see
Cheers Brogh
hi
maybe disabling the kde klipper app helps here.
its known to steal the focus of some programs and crashes the window manager in older
versions.
cheers
I can second that - I was having similar crashing problems until i killed of klipper - this was in RedHat 9 (upgraded with kde 3.2).. but it might be the same problem
