QUOTE(Dark_Knight @ 12/17/05, 10:40 AM)
I actually posted this information in another thread for Maya 6.0 on SUSE Linux 10 but it can be used for any Maya release and Linux distribution. By the way this information can be found in the included Maya documentation "Maya Help/Developer Resources/Environment Variables/Setting environment variables using Maya.env" and "Maya Help/Developer Resources/Environment Variables/General variables". Anyway, open the "Maya.env" which should be located in "/home/username/maya/7.0/Maya.env" and edit with your preferred text editor (Kwrite, Kate, etc) to include the following MAYA_DEBUG_ENABLE_CRASH_REPORTING = 1 which will enable this variable and use the value 2 to disable the variable. When Maya encounters a fatal error, this variable writes a crash report file (.crash) in the current working directory. This file contains a detailed description of what Maya was doing when the failure occurred. I also suggest checking your Linux distribution error logs which can also help clarify if it's software or hardware related.
[snapback]222648[/snapback]
i read that topic and somebody solved it but with little details.. as follows..
quote===========
CornFielD
post 10/18/05, 12:17 AM
Post #8
I have fully working 9600xt on suse 10.0
(or not completly selection marquee is mising and also there is couple of more driver issues in MAYA)
I tried to install newest ati drivers manually, but I didn't succeed with it, or yea in a way I did I got 3d to work, games worked well and those little benchmark apps *gears worked well, butt when i started maya it crashed on a start and gave me signall 11 error. (it worked without acceleration/openGL.)
then I just removed everything, made posix thingies modified fstab and mounted it again. as is written in the intallation manual. and then I just started ati's graphical installer. after that I ran fglrxconfig, Reboot and everything was working!
end quote============
it is exactly my prob. but i just don't understand what exactly did he do.
seems to have something to do with some "OpenMotif 2.2.3" libs that draw the interface for maya.
And here's what help says:
"OpenMotif 2.2.3
Maya 7.0 uses OpenMotif 2.2.3 as its GUI framework. The version used is
OpenMotif 2.2.3 from ICS with additional updates from the OpenMotif CVS.
Maya includes the library in its default lib directory, no action is
required to use the proper library.
http://www.motifzone.com/
Limitation
Maya may not run on systems that do not have a compatible runtime
libraries, including glibc compiled with the __cxa_atexit option. Maya
includes the C++ runtime libraries libstdc++.so.5, and libgcc_s.so.1
within the Maya "lib" directory, as well as the required Motif 2.2.3
runtime library libXm.so.3
Solution
It may be possible to copy selected .so files, however the precise files and locations vary on different versions of Linux and we are unable to provide replacement .so files, precise instructions nor provide Support on how to resolve this."
http://www.alias.com/eng/support/maya/qual...a\_65\_linux.html
so what to do?
the linux (suse10) libs are different ver. than those from maya lib folder.
what did CornFielD exactly do? overwrite the libs? wich ones over wich ones?
xfree or xorg?
if somebody can just get him to post a detailed walkthrough for this prob .
i tryed but no succes
