QUOTE(Jason Dane @ 04/12/09, 11:02 AM) [snapback]305556[/snapback]
so just to confirm there really is no way of doing this in Maya? Or will it be too complicated to do this for a simple effect?
It would be waste of resources more than anything else. So you would be saving time doing the right operations in the right place of the pipe.
And no its not hard to do just put a image plane on the near clip plane and fade in a ramp thats white and animate alpha. Just not very cost efficient in terms of flexibility.
QUOTE
The reason why I am asking is because I don't want to use any other software
You can not do anything with just maya IMHO. Your going to page into a comp app/cutting anyway for the final tweaks no matter what. How hard is it to pase a edl out of your scene.
QUOTE
The reason why I am asking is because I don't want to use any other software (as I doing a project and time is of the essence at the moment smile.gif ).
Well it uses up exactly the same amount of time but gives more flexibility to do it better. After all in comp this si prettymuch realtime, and you still need to page out to comp for compression and tonal fix. Anyway if time was so critical you allready spent it 10,000 over by asking. ![]()
