I recently installed Maya SP1 on openSuSE 10.2 When I try to start it the maya main window opens for about a second then closes. I tried launching it from the command line and got the following:
maya encountered a fatal error
Signal: 11 (Unknown Signal)
Fatal Error. Attempting to save in /tmp/username.20070806.1213.ma
Also, when installing Maya I also received this message:
/usr/aw/COM/bin/installKey: error while loading shared libraries: libXm.so.2: cannot open shared object file: no such file or directory
Is that causing this problem? Is there something I need to do about that?
Also, I don't know how to disable SELinux in openSuSE.
Any help with these problems is appreciated.
