Maya 8.5 Problem: Maya Blockes
Hi, I'm new and I'm modeling with maya 8.5 following the included tutorials. I've a problem: I'm doing this tutorial:
Getting Started with Maya
NURBS Modeling
Lesson 1: Revolving a curve to create a surface
I've the problem in the
Editing a revolve surface
when I move the "revolved" mesh, if I try to change his position, maya uses my CPU at 100% and I must close it with the Task Manager..I don't know why I have this problem and I want know if you can help me. I had the same problem in the tutorial
Maya Basics
Lesson 3: Viewing the Maya 3D scene
When I moved the Pedestal (cube) with the Base (sphere)
Must I unistall and install maya? Or is a common problem with a lot of users?
My pc config is the follow:
Athlon 64 3000+ skt 754 from 2.0ghz to 2.21ghz
Motherboard: Asus K8V-X SE (Agp)
Video Card: Sapphire Ati Radeon x1650pro agp 512mb overclocked to core: 662mhz and mem 493mhz
Power Supply: 350w Premier
O\S: Windows Xp Pro Sp2
Ram: 1gb DDR400 (selected as ddr333 with lowest timings) [512x2] V-DATA
Thank you for the help
otreblA
Hi mate hate to sound snobby but your pc is bouncing off the minimum spec. You're going to have to be careful as your pc won't be forgiving with over-complicated scenes, especially as maya likes to use over a gig of ram itself frequently. check in your task manager how much it is using before you attempt to move your mesh. also, turn on the object details in the viewport and note the number of faces on your surface (if a poly). finally, try to change the revolve surface options before you create it, by clicking the options box next to revolve surface in the menu. you can choose poly output with say a maximum of 1000 polys, then work your way up until you reach your limit. it's all about learning what your hardware can do, but when i had a 3200+ and an x800 i crashed it all the time, im on a dual xeon and quadro setup now but they don't come cheap..
hope that you get it to work.. ooh also delete your history it may be recalculating the surface from the curve when u move it..
thank you...I've a swap file of 1536 mb (min and max) and when I move the mesh, maya takes 400mb of ram and 100% of CPU....Maybe I must use a slower nurbs quality...then, when I made the helmet, in the scene I had 2 helmets: high poly and low poly..I moved them all and maya didn't blocked....why? Thank you
Try turning the maximum undo steps down by a notch.
Where must I go for do this? Thank you and sorry for my "noobagine"
