Didn't read joojaas reply here....it's loong...
QUOTE
I'll be the first to admit that I'm not a professional 3D artist or designer or architect, but I am interested in the medium, and see tremendous potential
So am I and likely another 50% of this forums users. Joojaa is way out there as her profile status says, so you should probobly always strongly consider what she says because she has the experience of everyone else on this forum combined...from what i'v seen. Then there are some other experienced users. And there are The Professionals- the ones that actually make a living out of this, which is not supposed to mean that they are more experience then some hobbyist...although it usually is the case.
QUOTE
I have been able to "create" 3D "objects" in Blender (saved in .blend format) which I subsequently exported to Wavefront .obj format. I was able to import those Wavefront .obj files into Poser 6 and 7. So, it is doable.
My expression "you cant make anything using poser and bryce" is not to be taken literally...I'll try to explain below.
QUOTE
What is the basis for your objections to these programs?
Poser...I'm not telling that it's bad...by no means. I'm telling that it's on a whole different level. The good thing about it is that it's simple so it's a good place for new users to start exploring CGI(3d) world.
What did i mean by "you cant make anything"? You probobly can, but typically poser users don't do that. You buy something that someone else made, and all you do is move it into places using some simple UI buttons. Maybe adjust it little bit, and then render (without getting into the more advance techniques). Therefore you don't create any artworks. What matters is not the result but the effort. I'd be more impressed to see a C++ programmed Cube revolving on the screen (which would take a good 500 or so lines of code), then the pre-made 101273..whatever polycount model rendered in poser. Of course the one person who should get the credit is the artist at E-frontier who actually modeled and even rigged it so fantastically. Once again. This is a great software for the right users, i know because i used it too, and many did, or do...I believe.
QUOTE
Maya 8.5 ple is merely a "get-to-know-the-software" trial version with no means of importing or exporting files. Is that correct?
PLE stands for Personal Learning Edition, so yes, its a trial version to test it out and see if you like it.
QUOTE
Another member Joojaa said something along the lines of:
QUOTE
No thetas the entire point of PLE. Its so you can practice but cant use it for working. If you could sawp files freely what would stop people form using ple for work. In fact you cannot bring anything out of PLE.
By 'working' I'm going to assume that this individual meant that nothing can be saved out of ple.
Yes, because Quote:If you could sawp files freely what would stop people form using ple for work, therefore nobody or less users would buy the software.
QUOTE
Makes Maya rather useless for the casual user...
Yes and no...In the first place is the price...a casual user has to really cut his expenses to be able to afford maya in most cases. Yes, when you get maya it's useless because you can't do anything with it, but you then have this huge opportunity to improve endlessly... At first it looks as if maya's slowing you down and nothing works the way it's supposed to work, and it's playing tricks on you and has so many buttons that you will never use know them all etc... Over time you get used to it and it gets better and better until it becomes second nature. So in the end..if you are serious about getting into 3d at the moment maya actually is your best bet (except the price again).
