QUOTE(Joojaa @ 04/23/07, 05:13 PM) [snapback]264680[/snapback]
just a question why why would you bother with all this if your own external implementation intend to use arrays? whats wrong with one of the following?
MColorArray
Because I am unware of the existence of these and don't see why I would need to use them anyway. Surely Maya can cope with a declaration like float arr[10]? Do I really need to use MFloatArray arr[10] instead in my C++ code? Wouldn't this just be a wrapper around a float array in any case?
So why would you try to implement something way beyond your skill set in first place? especially when theres a much more natural way. Anyway if you cant bother to read the api manuals yourself the entire point is moot. Because no one can help a person who's not willing to help himself? So either post your source, because your not demonstrating any progress here, and its jus ta matter of time till i label you as a lost cause.
I value your help but don't appreciate having assumptions made about me, thank you.
To answer your questions:
- Q: Why implement this? A: Because my employer asked me to. If there is a more natural way, then please let me know what it is.
- Q: Why aren't I reading the manuals? A: I am reading the manuals, but I haven't found the answer I require there; hence I'm posting a question here in the hope that I'll get the answer more quickly this way. So I hope you'll see that I am willing to help myself.
I can't post the source as it is company confidential. That is why I have only posted disguised snippets or descriptions of what I am doing. Here's an outline of my source that might be helpful. This is meant for illustration only and is not intended to be compilable.
enum { NUMRESULTS = 10; }
class MyClass
public: //members are public so that I need not provide access functions in this illustrative example
int value;
std::string str;
class MyNode
private:
MObject maya_value;
MObject maya_str;
MyClass obj1;
MStatus MyNode::readData(MDataBlock& data)
MStatus stat = MS::kSuccess;
MDataHandle handle;
handle = data.inputValue(maya_value, &stat);
value = handle.asInt();
handle = data.inputValue(maya_str, &stat);
str = maya_str.asString();
MStatus MyNode::compute(const MPlug& plug, MDataBlock& data)
if ((plug == output1) || (plug == output2))
if (readData(data) != MS::kSuccess)
return MS::kFailure;
double result[NUMRESULTS];
bool success = my_stand_alone_function(obj1, result);
if (success)
for (unsigned int i = 0; i != NUMRESULTS; ++i)
std::cerr << "Result " << i << " = " << result[i] << std::endl;
else
return MS::kUnknownParameter;
data.setClean(plug);
return stat;
class MyModel
//various simple types here, and also a variable of type std::pair<double, std::valarray >
bool my_stand_alone_function(const MyClass& obj, double* const arr)
MyModel model;
simplex simplex_method(&model);
//compute stuff here
//set elements of arr here
simplex makes copies of MyModel objects, so I MyModel has operator= defined that makes a deep copy.
Anyway i don't think your problem has to do anything with the smart pointers. Just something really fundamental
Right, that's exactly what I am thinking now, because I've got rid of the smart pointers.
Note that all my arrays are now fixed-sized arrays declared in header files. All instances of std::cout have been replaced with std::cerr, and all instances of printf have been removed (as the stack trace looks like it might have something to do with strings).
PS. Amway im beginning to see why the computer engineering majors were first introduced to scheme as a language to learn the vocabulary of programming to reset all the previous bad habits ![]()
Please don't post smart-alecky comments like these. They don't help. Be assured that my computing qualifications, experience and skills are well above average. It's just I have a lot of gaps in my knowledge of Maya, which is still fairly new to me.
Anyway im looking into your stack trace.
Thank you for your help. By the way, this posting was much more readable - thanks.
