another important step to this process is to make sure that you create project, and click on the use default settings (like already stated above). Then when you open maya, set project, then open your scene file. If you open your scene file, then set project, it wont work, I had these problems when I first started to use maya 2.0, simply because maya 1.0 wasn't quite as sensetive to doing the process this way.
