QUOTE(bohne @ 07/03/06, 08:31 AM) [snapback]241403[/snapback]
hi,
try to make the pattern for the collar be a part of the jacket pattern not so isolated. you may divide the collar into three pieces. the middle one for the back side and both outer pieces for the right an left front pattern. take the end spline of the jacket for the start spline of your collar. the pattern from the collar should not be continued upstream. it should be continued away from the neck, so the gravity do the rest.
i hope you understand what i mean. if not do another post and i prepare a scene where you can show how it works.
bohne
Hi - do not try to simulate the collar within cloth. Make a "stub" of a collar to which you should use to attach a static piece of geo that is wrap deformed to the original cloth garment. This is also the recommended method for attaching things like buttons, pockets, cuffs, belts, etc. Believe me, i've tried it all.
have a nice day
