Well, I hardly know anything about Maya but I work for a school and I have to install it on our PCs. It works well, FLEXLM works well and the Material Library is insatalled.
Any other tips on successful Maya configuration that would make sense in educational environment? Plugins configuration and such?
The question is this: There’s a number of issues we have to deal with while installing software at school. Namely mandatory profiles, user rights, directory permissions, group policies, harddrive protection schemes, Ghost. Normally with complex software we run into some problems at some point.
For instance we had to adjust permissions to make combustion work or we had to put c-dilla on a separate partition and redirect some folders to make 3d max work. Our C: drive is protected from any permanent changes - that can be a problem for certain software.
Thanks. We could do that. About the plugins - one of the Maya students here says that it makes sense to install plugins so they don’t load at startup but can be loaded later. What’s the procedure for this? At the moment we haven’t installed any plugins from the CD.
Also, our max classes get their meshtools, cspolytools and splinetools installed. Are MJPoly or something like that important at all?
go to the plugin manager and uncheck the load at startup option.
Remember that some plugins like fur I believe (if on unliimted) will be checked to load at startup
oh and one thing about the bonus games plug in is that you need to extract the scripts to the scripts>other folder not the scripts folder. Heh I was frustrated with that for a while till I talked to my teacher.
I’ve worked for two high end schools configuring and setting up machines for high end 3d and video workstations. All these machines have been running Windows 2000 (and I wouldn’t suggest any other OS aside from Linux).
Basically just make sure that you have a Scratch drive to throw the page file and temp stuff as well as for the students to save localy to. Make this something other then C: so you can still lock down C:. Some packages still need permission to write to their directory in C: as a USER (ie Premiere 6.5) so you will find a few exceptions.
If you are using a license server (FLEXLm) and your machines are identical just set up one machine with everything you want then GHOST it to the others…that has always been the easy way of maintaining machines in my opinion.
As far as plugins my motto has always been if it is free then it might as well be on the system because these kids are paying for those systems so I usually install every plugin and script from A|W and some from here at highend3d. It is the user’s Maya prefs that determine what loads at startup, by default (a new user just starting maya) it only loads what Maya loads by default on a clean install.
An absolute godsend for dealing with Windows 2000 and registry tweaks (like don’t put temp files to the PDC) is Winguides. While they don’t deal w/ 3d apps the general Windows problems have usually been brought up there. Make sure to check the forums there too!
Feel free to ask more specific questions…most of this stuff I feel I can do in my sleep now after so many machines - lol
Thank you very much for your reply. Our setup is very similar to what you are desribing. Two partitions, one for student work. C: is hardware protected, we also have group policies in place. We ghost C: partitions and it works with flexlm without problems. We run Win2k.
So you are saying that I can install plugins without worrying about all of them loading on startup? Since we use mandatory profiles user preferences won’t get saved and we won’t end up with different machines loading different plugins. By the way, if they DO want to save their preferences, is there a way for them to do that?
Allright, here’s the first issue that came up. Our machines logon as one user with a mandatory profile. What used to be “My Documents” is redirected to an unprotected Z: partition so people don’t save their stuff to C: and lose their work. Turns out Maya’s preferences are put in “My Documents”, root of Z: in our case. So whatever students do to the interface gets saved and all machines end up having different UI setup. Is there a way to redirect that preferences folder someplace else?
