Hi everyone.
I am having some difficulty using the various 3D channel effects in AE Pro with Maya .iff files.
I have rendered out a sequence in Maya as 8-bit .iff files, with z-depth enabled. I have confirmed in FCheck that there is z-depth data present.
When I bring this sequence into After Effects 7.0 Professional, none of the 3D channel effects (Depth Matte, Depth of Field, etc.) produce any visible effect whatsoever. I have tried a wide range of values, in both positive and negative, and can not get any sort of result. Either I have to be missing something or there is some problem here.
Does anyone have any advice on what I can do to make the 3D channel effrcts work? Please, don't simply respond with "After Effects sucks, use Shake or some other program," because that isn't an option for me.
Thanks in advance!
-Steve
