I'm using granite 3D texture in Maya 7 and the granite pattern repeats when I render in mr, no matter how I scale the place3dtexture node. When I render using maya software it behaves just like it's supposed to (texture scales with place3dtexture). Is there a workaround for this? If not, can anyone recommend a tutorial that can show me how to set-up a 3D texture in mr? I'm trying to make a shader for a rubber gym matte that is flat black with specks of blue and white. It's pretty easy to edit the granite 3D Texture into the matte with the maya software.
well maya 7 is old... and the shader libraries have become considerably better. Howevr im not sure its the problem, it may also be a export problem. See maya needs to convert the interna representation to mentalray equivalent. Unfortunately maya works differently form mr, so it can not be done perfectly.
To rule this out: Simplify your problem include ONLY the minimal ammount of nodes with no extra connections anywhere, if it still does not work then the problem can not be fixed inside maya directly. If it does then you need to alter your node network
