Hi,
I'm havin a few weeks of easy time as of now and have started to experiment with Maya on linux. Seems not to be too trivial task at all, first to get 3D acceleration working (ATI FGLX1, I know but it's not a time to change that just yet), then to install Maya. Sure enough, most of this stuff is not exactly on qualification charts.
First I tried SuSE as it has been told to work, version 9.2. Which does not seem to install Maya and says that the rpms are not good. I can't remember the exact error it gave, but the indication was clear that there was something wrong with the rpms (which is not true, I found out). Then I tried Fedora Core 3, which is on as we speak. Maya 6.0 installed quite nicely, with only a warning about a missing /tmp/magic something file. Running it caused a Signal: 11 when the GUI pops up, it has time to blink once or so and then it is gone. I updated to 6.01 which did not mention error of any kind when installing, but caused the Signal 11 as well. I patched to older openmotif rpms that came with Maya, stil lthe same, then replaced the libGLU.so, but no avail.
Now, any ideas? Somebody has got it to work with FC3 and ATI FGLX1? Or somebody has an idea how to install the rpms under SuSE? A lot of questions, but I'm not familiar at all with linux and pulling my hair off soon enough. I would have some old Riva TNT2 that I could pop in and test nvidia drivers if that would help?
2x AMD 2800+, 2Gb, FGLX1 if that is of any help.
