Is anyone running Maya on an overclocked Intel system?
I’m considering overclocking my Dual 650 but I’m worried about stability.
If you are overclocking, on what chip and what are you running at?
Thanks
Edited by disaac on 02/28/01 06:43:32 AM.
Thanks
i’m running maya 3 on a 700MHz Duron OC to 1000MHz with no problems if that helps any…the problems will not be in the overclocking as long as you have a stable motherboard and ram combo. the problem will almost always stem from your graphics board. if you get a high end card, it will almost always be guaranteed to work…i have a 3d labs oxygen gvx1 and it’s a rock in maya, never crashes and never get any artifacts. gaming cards are hit or miss. good luck!
Thanks.
Thats exactly what I was looking for.
I know you can run anthything on an overcocked system as long you can keep it running stable, but I know how proc. & mem. intense Maya can be at times so I thought I’d ask.
About the video cards you were looking at i would go for the firegl 2 the card is amazing.
nick
Video I’m OK, Oxygen VX1
Inexpensive, but gets the job done for now.
The issue you are going to have to deal with is that you are only going to be able to overclock by increasing the front side bus settings. This de-stabilises a system far more easily than simple multiplier increasing…
Get a copy of Prime95 and a way to monitor your CPU temperature. Check the thermal paste between your CPU and its heatsink - if you are using those pissy OEM HSF combos, go take a look at something a little more elaborate.
RAM timings are important for stable FSB overclocking..
Sean
