Hello,
Is there a way that Maya particles can paint texture map of an object. every particle hit an object it puts a white dot as big as the particle size on the texture of the object. I would like to use the final map as Alpha for other things. I made an example with photoshop just to illustrate what I am looking for. A is original, B is what is what I want.
Thank you in advance
