I might be misinformed, but I thought I've heard that it's possible to make a polygon object a cloth object instead of doing all the seaming process. Is this true, and if so, how do I do it or is it just a matter of using springs to sumilate cloth?
Hi.You can make cloth objects from any nurbs or polygon meshes.Nurbs will be converted to poly.
Cloth > Create Cloth Object
But I think it's easier to make the UV map from the panel.Later you can delete history, and make it a cloth object again.
