Maya Shatter Script
I am looking for a script I saw on line called Maya Shatter Script. I have searched the net and no luck. Below the video of the script.
http://www.youtube.com/watch?v=8AWdHa0Hz-0
Thanks for the help:)
Looks uselessly slow to me. But then booleans are. I dont actually see any reason why it would work any better than mayas internal shatter DEMO (yes its a demo edit it if it does nit suit your needs), it's not actually demonstrated in any problem situation thet would arise.
Besides it looks more or less exactly like the internal shatter, just some more prams, you could easily modify teh existing mel scripts.
What exact shtter effect are you after.
Thx for quick response.
Blow up walls using Nima/PhyX.
I am looking something like Blastcode. I want more detail shatter. It only gives me 32x32 Pixel size (for demo verison/cant afford the plugin sniff) for map and it only works with nurbs (I think). I also have dome want to blow up and Blastcode makes the dome look not so good when you apply texture.
Split it up your self its not actually all that hard and you get final controll of the effect.
Blastcode isnt as good as it sounds. Doing things yourslef allways has a sight edge because others dont know the exact need s you have.
