Hi guys!
Finally made the move to Linux and i’m loving it. But one thing, namely the spacebar acts kinda funny, sometimes i have to press it a couple of times until it does the job. Is there a setting i might’ve overlooked, or a trick of some sort?
Maya7
Suse10
FX 1100 with the 7676 driver.
Thanks a lot,
Cheers
Note: Sorry admin for posting in a second forum, i just realised there is a Linux forum.
Actualy it turns out it does work properly if i dont move the mouse, which kind of slows down the workflow a tiny bit.
Is there a way to fix this?
Thanks!
QUOTE(CuzzinLouie @ 11/14/05, 02:27 PM)
Hi guys!
Maya7
Suse10
Thanks a lot,
Cheers
[snapback]219678[/snapback]
I haven’t experienced any issues with Maya 7.0 on SUSE Linux 10.0 and I’m using the same graphics driver release. If you click the space bar with a quick tap then you can change views. If you hold the space bar down then Maya’s Hotbox should open allowing you to make a selection with your mouse.
OS: SUSE Linux 10.0 (32-bit)
Kernel: 2.6.13-15-smp
Desktop: KDE 3.4.3
glibc: 2.3.5-40
GCC: 4.0.2
OpenMotif: 2.2.3-13
libstdc++: 4.0.2
QUOTE(Dark_Knight @ 11/17/05, 09:20 PM)
Desktop: KDE 3.4.3
glibc: 2.3.5-40
GCC: 4.0.2
OpenMotif: 2.2.3-13
libstdc++: 4.0.2
[snapback]219987[/snapback]
Hm DarKnight, CuzzinLouie wasn’t saying his hotbox doesn’t operate at all, he was saying it doesn’t work as advertised _while he’s moving his mouse_. If mouse is stationarry, tapping hotbox will work ok.
CuzzinLouie: unfortunately its a known issue with Maya for Linux (it didn’t exist in Irix, doesn’t in Windows, don’t know about osX). All you have to do is get used to halting your mouse whenever you want to tap into other views with spacebar…
Hi there, I had the same problem. To solve it on kde go to the Configure Window Behavior window and on the focus part, change the policy to: focus follows mouse and uncheck the auto raise and the delay focus and check the click raise active window
don
Hm, nope, it doesnt work for me.
Are you on Suse10? So you can switch viewports while moving the mouse?
Thanks!
