Hi everyone i am new in mel i need help i have basic idea about mel i need to trigger a if statements or global proc when i start to grab the maya time slider and print each frame time
When i am scrub though i searched though maya mel documentation i tried maximum i can.
Now i am confused that mel is capable to do this or i need to goto maya cplusplus api
All kind of help accept thank is advance .
You can do this via 2 ways each has its implications.
- Via scriptJob (it is executed when you release the mouse after changing the current frame, so it does not work while dragging):
//define a proc to run and put the code you want to excute inside
global proc printTime()
print ("frame: " + currentTime -q + "\n");
//create the scriptJob, it is triggered when the time changes
int $jobNum = scriptJob -e "timeChanged" "printTime";
//delete scriptJob
scriptJob -kill $jobNum -force;
- Via expresion ( it is executed each frame, works while dragging and changing frame in the timeslider):
Create the expresion and put the code you want inside (expression syntax is a little different than pure MEL, search documentation)
ex (run the following code to create an expression):
expression -e -s "print (\"frame: \" + currentTime -q + \"\n\");" -o "" -ae 1 -uc all printTime_exp;
It is advised not to run getAttr/setAttr commands inside expressions for performance reasons though it is possible.
Thanks this is exactly what i want but the second expression i dont really understand it
I run those command in mel i got error i attached that error
I dont get or set any value i just want to save currentframe value in to int arry while dragging
Now i am trying to learn expression syntax
Sorry, my mistake. That statement is trying to edit an existing expression:
Next one creates a new one with the name "printTime_exp";
expression -s "print (\"frame: \" + currentTime -q + \"\n\");" -o "" -ae 1 -uc all -n printTime_exp;
Go to the Expression editor and there you can create and edit expressions.
Yes its working I need one more help how can i assign that frame value into a array . Thank you
expression -s "// declare a global string array\nglobal string $frames_array[];\n\n// reset array on frame 1 if needed\nif(frame == 1)\n\tclear($frames_array);\n\n// add current frame to array\n$frames_array[size($frames_array)] = currentTime -q;\n\n// print current frame\nprint (\"frame: \" + currentTime -q + \"\n\");" -o "" -ae 1 -uc all -n printTime_exp;
// Go to Expression Editor to see the code.
