QUOTE(gormanj @ 07/18/07, 12:00 PM) [snapback]269946[/snapback]
[url=http://wiki.secondlife.com/wiki/Advanced_Sculptie_Exporter_From_Maya]http://wiki.secondlife.com/wiki/Advanced\_S...orter\_From\_Maya[/url]
This is pretty much what you need to "sculpt" in second life.
In basis you create a NURB Model, from which this MEL script (provided in that link) takes in as NORMAL map data (SPHERICAL) into a TGA/BMP/JPG. this is then uploaded into second life, and with special "prims" (aka building blocks) you set them to have the normal map (SPHERICAL), (in this case, known as a sculpty).
The MEL script will also construct a file from which you can copy "data" to a in-world script which will process it, and reconstruct a NURB scene from Maya.
I personally use EP curves or NURB spheres to start the modeling.
