I've been using Maya now since I purchased my 7800GT and have always had the same problem. Only now the issue is much more severe.
Whenever I would exit the program, my screen would flash to black, similar to a screen resolution change, and then back to windows again. Now that I'm installing plug-ins for the program (seemingly irrelevant to my video card), it will do this with more severe symptoms:
- Starting up takes about 1 minute with a 'No Signal' being displayed for the duration and occasional screen flickers.
-Using any tool from the shelf of one of these plug-ins causes an approximate 3 second screen flicker, similar to the one while closing the program.
I'm 90% certain that this is a video card issue. I have dl'd the latest drivers, turned off triple buffering, and changed my screen refresh rate. I'm wondering if anyone has had similar symptoms as the ones I've described. I'd greatly appreciate a solution to this, as nvidia suggested purchasing a Quadro card for 'high-end 3d software' (I'm sure they would like $2,000). My x800 worked perfectly and I'm almost wishing I had kept it instead.
