Maya4.5 for Linux - weird problem @ startup
Hi all,
since last week I've got Redhat 8 as my main OS and of course I want to
work with Maya on it too G
So I've grabbed my Maya4.5 CD, installed everything (no problems @ all), rebooted and
tried to start it with "maya"
Maya startscreen pops up, Maya loads, Interface appears, I can read "preferences saved" in the lower right corner and WOOSH
- ITS GONE!!
Immediatly after the startup it shuts itself down and I have NO idea why! Absolutely no...
I asked every maya specialist I know and noone seems to know ANYTHING
At the terminal I got:
/usr/aw/maya4.5/bin/maya.bin encountered a fatal error
Signal: 6 (Unknown Signal)
Attempting to save in
/usr/tmp/faeroon.030103.2223.ma
The same problem was posted here:
http://www.highend3d.com/boards/showflat.php?Cat=1http://www.highend3d.com/boards/showflat.php?Cat=1,2&Board=linuxforum&Number=127299&page=1&view=collapsed&sb=5&o=&fpart=
If anyone knows how to solve this, has a hint or whatever - please let me know!!
Thx in advance
Faeroon
PS: I've heard that RH 7.3 hat the gcc 2 and RH8 has gcc 3 and this
is not compatible to old version... maybe this is the source of the problem?
doesnt want to downgrade
First things; tell me some more about the system
video card; drivers run on the video card
RAM and swap;
all that jazz..
CPU: Intel P4, 2,7Ghz
graphics card: GForce4, run with newest nvidia linux driver
RAM: 1GB
Swap: 2GB
HD: 100GB
System: newest Redhat 8, dl'ed from Redhat FTP one week ago
WM: KDE
Installation: full - everything
The system runs absolutely flawless, no problems at all.
Even the maya install made no errors or anything - the only thing is
that maya starts up and shuts down :-/
Hrmm what window manager are you running? KDE?
Hehehe, yep - just edited my post.
are you running any strange themes? or just the default?
try flipping over to gnome and seeing if maya will run fine. I've had it crash with some wm themes. Its a long shot but worth a try
Nope - I'm just running the default KDE, no themes, funky icons or whatever.
I've just tested Maya with GNOME and Windowmaker - the same as usual
Starts up, shuts down - error 6 in the terminal sighs
odd; I can't reproduce here on my end.
tried an older driver release?
wasn't maya not supposed to run on newest rh but on 7.2 instead? (maybe i'm wrong). Anyway, rh modifies the default linux kernel which in my oppinnion is what causes lotsa problems on rh ) try getting 2.4.20 (or whatever is newest now) from kernel.org and recompiling it
untar, than type make menuconfig, than choose your system stuff than make dep, make clean, make modules, make modules_install, make bzImage cd ~/./bzimage *wherever it is, cp bzImage /boot, add it to /etc/lilo.conf, lilo, reboot.
What is your XFree86 file look like? marked out dri and the other thing like in readme for driver?
Does your kernel support more than 2gigs of memory per process? (in makemenuconfig you'll see support for large memory somewhere), if not shrink your swap partition so it has less than 2 gigs when added to physical ram size. see if your c compiler is compatible with maya4.5, if xfree is compatible, if libraries are preloaded prior to starting maya 'export LD_PRELOAD /usr/aw/maya/lib/*'. Did you install openmotif or just use maya4.5's built in one? install it you got it on a cd its free and they say better than free lesstif thats available with rh, some confilicts there... did you uninstall messa openGL prior to installing nvidia's?
blah blah, could be so many things )
Yep, yesterday I've downloaded RH7.3 and I'm going to test that out in about ~1hour
I can't answer all your questions because I'm still new to linux but for example
I did not install the OPENMOTIF from mayas CD because it tells me that the one
that is pre-installed by RH is newer than the one I'm trying to install.
Uninstall opengl .... :-/ Nope? Can someone tell me how to do this?
Anyway, in about an hour I'll install 7.3 and then we'll see if all the talk about maya<=>7.3 is true
afraid to tell you this, but Maya4.5 runs fine (so far) under RedHat 8.0.
P4, KDE/gnome, w/ latest nvidia driver.
I'd suspect that problem relies on something else..
-ck
i would call tech support at Alias Wavefront - that is if you have support (and are legal). Thats what they are for.
haha the irony from a man with l337 in his name
hehe
anyhoo
it won't likely be a kernel issue unless your using the kernels DRI or AGP drivers.
redhats kernels are actually pretty solid; we have them running in several production environments at customer sites.
if you'd like the most robust of redhats kernels; fetch the kernel 2.4.9-e10 source rpm from ftp.redhat.com
then issue an rpm --rebuild kernelsourcerpmname
then go into /usr/src/redhat/RPMS and install that with
rpm -ivh kernelname.rpm
you want to do a -i and not a -U to ensure that if something goes wrong; the old kernel bin image is still there.
Didn't think about the lesstif thing though; that is a very good point. Might be worth it to roll back to the openmotif that A|W provides on the CD.
rpm -e rpm -qa | grep lesstif
rpm -ivh openmotifrpm
anyway
back to customer issues
When I installed RH8, there was an optional install of a second openmotif library for backward compatibility. I believe maya need this other openmotif library. If find out the name of the rpm on the cd when I get home.
I have the same problem as the starter of this thread. If you run Maya from the console, this is spit out:
Maya, Version 4.5, Fri Aug 16 01:26:23 EDT 2002
Copyright 1997-2002 Alias|Wavefront, a division of Silicon Graphics Limited.
All rights reserved.
Graph Layout Toolkit
Copyright 1992-1997 Tom Sawyer Software, Berkeley, California
/usr/tmp/Exdaix.030109.1718.ma
Exdaix.030109.1718.ma seems to be the blank scene that is created, (the 1718 part changes since Maya makes a new one every time you load it) it creates the file with a lot of text in it, none of it has error messages in it though. It seems that Maya is having some trouble saving data to the created (and filled with text) .ma file.
Any ideas?
I had exactly the same problem with RedHat 8.0. After many try ... i finded that is the color depth the problem... X-Windows must be set to 32 bits(or 24 bits). So, go to yours XF86Config files and change de depth value to 24.
Excellent! It worked great! Your the first to find a solution to this specific problem alot of us are having. Thank you very much!
