here on the forum that describes how to install maya6.0 on debian, however im using Maya6.5 and i was just wondering if the process is the same or if anything has changed? Im also using a nvidia card so the tutorial fits me perfectly, thanks Musashi!
now its just time to figuere out how to get rid of this gdm window manager which i feel are sucking up way to much memory, and/or remapping some keys to get the alt+mbutton to work in maya
you can choose the loginmanager in the file “/etc/X11/default-display-manager” or you remove every GUI loginmanager and login on text and start with “startx”
but also xdm should save your memory (apt-get install xdm)
Or do you mean your WindowManager at all ? Then taste xfce, openbox or sawfish.
I use openbox, you can edit the menu on right mouse button in file /etc/X11/openbox/menu.xml, and key bindings in file /etc/X11/openbox/rc.xml
I don’t really know how remove the ALT key binding on Gnome . . .
