MEL 2 PlugIn?
Hi!
I wrote a LSystem-MEL scrip, which grows some corals. Now I would like to convert it to a PugIn. Do I have to rewrite the whole stuff in C++ again (argh!), or are there other possibilities to convert it? It would be enough to get an interface-window in order to interact with the script. So if ther isn
There was another similar post to this floating around in the last day or two, though I can't remember in which forum.
Unless you need to protect the source code in some way, there isn't much reason to bundle up MEL into a plug-in. You can write the UI in MEL.
--JeffD
