Mel Script equivalent to Python's "variable{0}".format(var)?
I’ve been using Python to drive Maya for a while now and love it. Writing up an expression now which is in Mel and sort of stuck on how to emulate the format command in Python. I have a number of like named nodes that I need to perform an opration on using a for loop.
How do I splice my counter of the forloop into the node name I want to operate on?
loose example of python/mel mashup below for example-
for( $i=0; $i<4; ++$i )
keyframe -index 1 -absolute -valueChange $maxHeightPad pad_t{0}_animCurve.format($i); //  <------END OF THIS LINE
Thank you for the help. Honestly I don’t know what this operation is even called in Mel Script or I would of found it by now.
I’m not really familiar with python, but if you just want to add the loop increment to the name you can do somwthing like this:
for($i=0;$i<4;$i++){
keyframe -index 1 -absolute -valueChange $maxHeightPad  (“pad_t” + $i + “_animCurve.format”);
