Mel scripting help?
Hello,
I was wondering if someone could help me write a MEL script that would allow me to do this:
select objectA
if objectA does not exists, then skip
if objectA exists, then put in on a Layer and rename it LAYER_A
if LAYBER_A already exists, then skip
select objectB
if objectB does not exists, then skip
if objectB exists, then put in on a Layer, rename it LAYERB.
if LAYERB already exists, then skip
Thank you!
Hi zero_steph,
Here is your MEL script =), (but Python is best ! :slight_smile:)
You can apply the same principle for objectB and LAYER_B by replacing the text between the double quotes on the beginning of the script
Peace,
Mehdi
That worked great, thank you very much!
