Mel, Webbrowser And Flash
Hi...
I want to make a rig UI in flash and/or html...
1- how can I do since the commande webBrowser is dead. I can put my UI in FireFox, but I want put my Flash Layout in a MEl standard UI... is it possible?
2- Other question : how can I do to move an object in flash, and send the position to maya in a object?
Thanks a lot for your answers
Use command port, hell you can use maya as web server if you wish.
QUOTE(_timou_ @ 03/26/08, 08:38 AM) [snapback]283218[/snapback]
you just need to load the browser plugin (under help)
on the flash side the command that makes it all happen is getURL
for example:
value = clipName._y
getURL("mel://setAttr nodeName.attribute "+value);
QUOTE(Joojaa @ 03/26/08, 12:35 PM) [snapback]283232[/snapback]
hi... thanks for you reply...
but what I need is to have a layout in flash...
for exemple to have inside a maya windows taht I created in MEL, a part in flash (to make a selector window).;.
