Memory: How much and what brand?
I’m trying to find out, first, just how much memory is enough to work in Maya painlessly, I know “the more memory, the better performance” but what is the optimized number for a workstation?
Then, does it make any difference if memory is installed in larger modules, like 2 x 1GB comparing to smaller modules, 4 x 512MB?
And finally, I’m considering Kingston, are they good? I know that Corsair is the best but the price tag is kinda high. And one more question I’ve heard that Xeon processor along with Intel 7505 chipset support only DDR266, is this true?
thanks,
Michael
there is no optimized number - but recommend at least 1GB for painless workflow… with more if you can afford it. remember, 32bit windows cannot use more than 1.5GB or ram per thread, so anything more than 2GB and ur wasting u money
it doesn’t matter if you have 2 x 1GB or 4 x 512MB, and with the Athlon64 it doesn’t matter if you have an odd number or DIMMs (it only has a single memory controller). the only difference is with the dual channel Opteron, where u should use multiples of 2.
the brand of RAM makes no difference, i’m using dirt cheap 400MHz V-Data ram and its fast and stable
and finally, the Xeon… i wouldn’t bother with it… P4s are quite fast for an SP solution, but very expensive. Athlon64’s are fast and cheap. the only good DP solution is the Opteron :stuck_out_tongue_winking_eye:
Thanks Cipher, but I thought that 32-bit windows can address a maximum of 4GB physical memory, where it reserves 2GB of that for Windows kernel and give the other 2GB for applications.
So with a 4GB total RAM, the workflow within Maya should be improved with 2GB dedicated for windows and 2GB for Maya use, am I right?
This is an article on Windows 32 and 4GB memory limit:
http://www.brianmadden.com/content/content.asp?id=69
Michael
in theory it is supposed to - but i’ve heard repeatedly it doesn’t handle large amounts efficiently. the studios i’ve visited have 1.5GB per workstation.
having said that XP-64 ES is supposed to be here end of this year so anyway… which can use heaps
Ok so windows can alocate 4 Gb but it CANT allocate 4 GB for each thread, so each program is alotted a 1,4 something Gb off memory form that 4 Gb, nothing more is possible! It is possible but not cost effective to start 2 therads for an aditional slot of mem…
A xeon can use more than 1.4 tough but only on aserver suystem and a special prog!
So what you guys are saying is that,
Running Maya on Windows XP 32-bit; It really doesn’t matter if you have 2GB, 4GB or 16GB of memory, Windows would only let Maya to use 1.5GB of your system’s physical memory. Right?
Michael
Not realy…
se if you used maya and phtshop dfor instance then both could use a 1.5 G slice… so if you have 2 than maya is free to use 1.4 something because its on a different slice than other apps and the OS offcourse!
Yes this is pretty much true although from my experience it is more like 1.3GB. There is however a boot flag for windows XP that will allow the system to recognize up to 3GB of ram and some applications will use the addtional ram. I’m not sure if Maya 6 is one of them.
No, Maya 6 is only able to use 1.5GB memory, as you can see from the other discussion here:
http://forums.alias.com/webx?128@253.GVpGahRjeEZ.6@.2cc27628
But the number of memory dimms does make a difference, on a mainboard with memory-interleaving support; With two 512MB dimms vs. one 1GB dimm and 2-way interleave, memory bandwidth would double, and on mainboards with 4-way memory interleaving support, you get four times better memory bandwidth if you install four 256MB dimms vs one 1GB module.
As most high-end workstation class boards come with 2-way memory interleaving support, and you could get a board with 4-way support for extra bucks.
Michael
