Im not attacking im just wondering how the hell you can be so adamant about the fact that its not your fault? I mean atlest saying it might be your setup is better than saying maya has a leak wich is definetly a bug, and your sure its not in your setup.
I eman a configiration problem is faar more likely, taking in cosideration what youve said. Tough its faar likely to be a combination of BOTH theese things anyway if you can circumvent by reconfiguring why not do so?
Im sure there are many resident bughs in maya but if others can circumvent theese poroblems then you should try to do so too, instead whining try to do something about it. Whining never takes you out.
Im trying to get you to look at facts wich may lead to you getting the problem solved, while you are so intensely angry that you fail to se it. I can understand that, but being angry is not the time when your most openminded.
Mind you a text based forum is allways about 2 time as hostile as truth when you cant see or hear the rone of peoples voices, and yes sometimes voice of reason needs a huge mallet to go to peoples heads. Im not hostile towards you. Im just trying to woigh the facts as whats the most likely problem, As more and more people start to claim they have solved the problem it seems im right!
