Mental ray and displacement?
i tried to set the quality for displacment map by setting the inital/extra sample rate, but when rendering with mentar ray it doesn’t work. it only works for maya software render. so is there any way to change quality of displacement when rendering with metal ray???
PS: …or at least how can i turn displacement off (to speed up test renders)
mentalray uses a own superset… use the mentalray approximation editor to do this (suggest you use spatial fine! view dependent with a value of 1 or so)
thx a lot
…just one more thing, how do i turn displacment off (temporarily)?
something like “Feature Displacement” checkbox??
suspend connection by rightclicking on the name in the shader!
